anncarina hat geschrieben:OHO ein neues TSI? Wie sieht der Rep Satz aus? Ich kenn nur neue Simmeringe
Der Rep-Satz besteht aus Dichtung und C-Clip.
Das TSB in aller gebotenen Kürze:
TSB 05-15-5 LEAKS FROM REAR HALFSHAFT AXLE SEAL
Publication Date: July 13, 2005
FORD: 2002-2005 Explorer
2003-2005 Expedition
LINCOLN: 2003-2005 Aviator, Navigator
MERCURY: 2002-2005 Mountaineer
This article supersedes TSB 04-10-5 to update the vehicle lines, model years, Service Tips and labor operations.
ISSUE:
Some Expedition/Navigator vehicles built before 2/16/2005 and Explorer/Mountaineer, Aviator vehicles built before 3/18/2005, all equipped with the 8.8" or 9.75" ring gear and independent rear suspension (IRS), may exhibit leaks at the rear halfshaft axle seals. A new unitized seal is now available for service. The new seal design eliminates the need to use seal protectors during installation. Removal of the excluder seal (1L2W-1N013-BA) if present is required.
ACTION:
Order and install the new seal to correct leak condition. Review the Instruction Sheet included in the kit and obtain the required tools before beginning repair. Refer also to the following installation Service Tips.
INSTALLATION SERVICE TIPS
Refer to Workshop Manual Section 205-05 for half shaft removal and installation.
Use only the proper seal installation tool, Rotunda tool (206-034).
Ensure the seal installation tool is clean and free of debris prior to inserting into new seal. Do not use a damaged seal installation tool exhibiting nicks, burrs, or sharp edges.
NOTE: THE USE OF SEAL PROTECTOR 1L2W-4N206-AA IS NO LONGER REQUIRED.
Do not tap directly on the back of the seal installation tool, always tap on the handle, per Instruction Sheet. Seal should be driven evenly into housing bore with only enough force to seat in the bore.
Before installing the halfshaft, verify that the inboard excluder seal (1L2W-1N013-BA) is not present on the halfshaft. If the excluder seal is present, follow the kit Instruction Sheet and remove the excluder seal.
NOTE: OVERFILLING THE AXLE CAN INCREASE POTENTIAL FOR LEAKS. LUBRICANT SPECIFICATIONS CAN BE FOUND IN THE WORKSHOP MANUAL.
PART NUMBER PART NAME
5L1Z-4A109-A Axle Seal Kit
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
051505A 2002-2005 Explorer/Mountaineer 2003-2005 Aviator Replace One Rear Axle Seal (Do Not Use With 4139A, 4139AT, 4139A2, 4139A2T) 0.9 Hr.
051505A 2003-2005 Expedition/Navigator Replace One Rear Axle Seals (Do Not Use With 4139A, 4139AT, 4139A2, 4139A2T) 0.9 Hr.
051505B 2002-2005 Explorer/Mountaineer 2003-2005 Aviator Replace Both Rear Axle Seal (Do Not Use With 4139A, 4139AT, 4139A2, 4139A2T ) 1.7 Hrs.
051505B 2003-2005 Expedition/Navigator Replace Both Rear Axle Seals (Do Not Use With 4139A, 4139AT, 4139A2, 4139A2T ) 1.5 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
4A109 42
